It is currently Mon Sep 15, 2025 2:57 am
PostPosted: Tue Jul 09, 2024 4:12 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I started a Black Limba acoustic just because it had a pretty grain pattern. After I had the blocks glued to the rim, I bumped it against the table while moving it. I split and splintered such that I won’t be repairing it. On closer inspection, it was apparent that this wood doesn’t have much strength in the thicknesses we build with. I started to worry about the longevity of the completed guitar. Does anyone have any experience building acoustics with this wood? Is it strong enough in a completed guitar? I can get more sides and continue, but I wonder if I should. I don’t want to set a guitar loose that will crumble if it’s handled roughly.
This one was going to be one of my named series. (“Korina, Korina”)
PostPosted: Tue Jul 09, 2024 4:30 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Taylor and Larivee, among others, have used black limba for acoustic guitars. Taylor has used it on multiple models. So maybe it was that particular piece of wood that was problematic.
These users thanked the author J De Rocher for the post: bobgramann (Tue Jul 09, 2024 6:11 pm)
PostPosted: Tue Jul 09, 2024 5:46 pm
I’ve made a dozen or so with it without issue. It is very soft and light, and easy to dent. You can even crush the faceplate by tightening the tuner grommets too much. Very much in the warn spectrum tonally…
These users thanked the author meddlingfool for the post: bobgramann (Tue Jul 09, 2024 6:11 pm)
PostPosted: Tue Jul 09, 2024 6:12 pm
Last Name: Gramann
State: VA
Thank you. I will continue, then. First, I will get some more sides.
PostPosted: Thu Jul 11, 2024 8:29 am
First name: Matthew
Last Name: Dalton
I've built two with Black Limba, an OM and a OO. The OM was my first build, now 2 years old, and has had zero issues. It's not perfect, but that's definitely not the wood's fault! I actually really like the way it sounds. My 8th, just finished last month, is a OO I built to give my daughter for graduating high school. I had it on my bench while I attached the neck, and a shall-not-be-named member of my family bumped it. It fell, and the bass side split from the neck to the tail. The split was easy to cleat and seal (I was actually pretty happy with the repair job...my first of that nature), and I feel certain my failure to add side reinforcing strips of cloth (as I normally do) contributed to the length of the crack, so again, probably not the wood's fault?
That was a long way of saying I, a newb, like it and would definitely use it again.
PostPosted: Thu Jul 11, 2024 10:09 am
I've heard said it's a drop in replacement for Mahogany and can make a really nice good sounding guitar.
These users thanked the author Colin North for the post (total 3): Pmaj7 (Thu Jul 11, 2024 3:59 pm) • Treenewt (Thu Jul 11, 2024 11:44 am) • bcombs510 (Thu Jul 11, 2024 10:13 am)
PostPosted: Thu Jul 11, 2024 11:44 am
First name: Matthew
Last Name: Dalton
That is a BEAUTIFUL back!
PostPosted: Fri Jul 12, 2024 3:52 am
Neck was quite nice too.
These users thanked the author Colin North for the post: Treenewt (Fri Jul 12, 2024 7:20 am)
PostPosted: Mon Jul 15, 2024 12:46 pm
First name: Zac
Last Name: Stout
City: Floyd
State: VA
Zip/Postal Code: 24091
Black limba is an excellent tonewood! I’ve used it in two instruments so far with great results and I plan on building many more with it. As Colin already noted, I’ve found it to be a drop in substitute for mahogany in both tonal qualities and workability. Pricewise, it’s on the lower end of the spectrum as well. I’m finding the price of a back and side set to be in the $100-150 range, but if you have resaw capability the lumber is available much cheaper - I bought a beautiful board for $100 last year that should yield 5 or 6 guitar sets.
The D-18 I built is about 4 years old now and has developed into a powerful flatpicking guitar with the same quick attack and decay you’ll get from a good mahogany dreadnought. The weissenborn is a little over 2 years old and has a warm, woody tone that just sounds so sweet when played with the steel slide.
When building my weissenborn, I didn’t have a side mold for my bending machine and attempted to bend by hand on the hot pipe. Under the advice of a friend, I soaked the sides for a few minutes before bending and developed deep rippling across the grain that rendered the sides unusable. I made a mold and bent my second set on the bender with a light spritz of water on the wood and the paper envelope and the results were perfect. Sample size of one, but it would seem that bending on the dryer side yields better results.
These users thanked the author Zac Stout for the post (total 2): Pmaj7 (Tue Jul 16, 2024 8:23 pm) • bcombs510 (Mon Jul 15, 2024 2:03 pm)
PostPosted: Mon Jul 15, 2024 12:48 pm
First name: Zac
Last Name: Stout
City: Floyd
State: VA
Sorry for the repeat pics in the last post, not sure how that occurred!
PostPosted: Mon Jul 15, 2024 2:03 pm
First name: Brad
Last Name: Combs
I got to hear / play the weissenborn a couple years ago. It sounded great!
These users thanked the author bcombs510 for the post: Zac Stout (Mon Jul 15, 2024 3:55 pm)
PostPosted: Mon Jul 15, 2024 4:21 pm
First name: Matthew
Last Name: Dalton
Zac, both of those are beautiful instruments! Well done!
I had a nightmare of a time bending my first set of Black Limba on my very first build, but had no trouble at all with the most recent. I went with a spritz of water on the side, (slat-aluminium foil-side-aluminium foil-blanket-slat) and they bent like a dream. My first guitar has a black limba neck and it's held up nicely.
These users thanked the author Treenewt for the post (total 2): Pmaj7 (Tue Jul 16, 2024 8:24 pm) • Zac Stout (Mon Jul 15, 2024 6:52 pm)
PostPosted: Mon Jul 15, 2024 4:27 pm
Last Name: Gramann
State: VA
I am glad to hear all of these positive statements about Black Limba. I’ve obtained another set—the new one looks even better than the side I broke. I think I have a plank coming from which I can cut new sides, so I’ll end up with two Black Limba guitars. StewMac had some neck planks for sale, so I’ll have matching neck wood as well. I look forward to continuing on this guitar. Thank you to all.
PostPosted: Mon Jul 15, 2024 10:07 pm
Last Name: Colbert
City: Anacortes
This is a Black Limba 28” Baritone Multi-scale
These users thanked the author Michaeldc for the post (total 3): Treenewt (Tue Jul 16, 2024 1:26 pm) • rbuddy (Tue Jul 16, 2024 9:42 am) • bcombs510 (Tue Jul 16, 2024 1:46 am)
PostPosted: Tue Jul 16, 2024 3:41 am
Nice one Michael, what scale length did you use?
PostPosted: Tue Jul 16, 2024 6:20 am
Last Name: Colbert
City: Anacortes
28” over 26-1/2”
PostPosted: Tue Jul 16, 2024 1:26 pm
First name: Matthew
Last Name: Dalton
That is beautiful! Did you use Wenge for the neck?
PostPosted: Tue Jul 16, 2024 7:23 pm
Last Name: Colbert
City: Anacortes
Thanks!
No, it’s ebonized sapele.
These users thanked the author Michaeldc for the post: Treenewt (Wed Jul 17, 2024 10:49 am)
PostPosted: Tue Jul 16, 2024 10:59 pm
I've got a few 8/4 boards of Limba, but I haven't resawed any back and side sets yet. I bought these a few years ago on the recommendation of Tim McKnight. He's used it many times and says it's ideal replacement for Mahogany. Black Limba and White Limba come from the same tree, it's just cosmetic.
PostPosted: Wed Jul 17, 2024 2:29 am
Yes, cosmetic, but seem to be spalting. In some places mine was very soft requiring CA to firm it up for finishing as it just kept soaking up the finish like a sponge.
Users browsing this forum: No registered users and 42 guests
